Results 1 to 10 of 10
    Feb 2003
    USA Heart of Dixie
    Any good software for ripping cd's (free) ?
    Coffee makes you happy.....Except when it messes you up
  2. Hum... media player?
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    You don't say whether you're ripping music or software, so I'm moving this to Newbie/General forum.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Musicmatch used to let you rip at 128kbs mp3 for free with a nag screen. I don't know what the newest versions limitations might be. Worth a check though
    Kevin
  5. Banned
    Sep 2004
    Inner Circle of Thought
    Winamp will also let you rip cd's.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I use CDEX. Excellent.
    If in doubt, Google it.
  7. Member NamPla's Avatar
    Jun 2004
    Whoop Whoop
    CDEx all the way!
  8. Originally Posted by yoda313
    Hello,
    128 = garbage.
    EAC and Lame Encoder are the way to go. Takes a little time to set up but thereafter it's solid.
    Great error correction / reporting if you have a good drive.
  9. Banned
    May 2003
    Massachusetts
    The BEST quality, bar none, is to be found from Exact Audio Copy.
    Now, some drives have issues with EAC, the author is overworked and underpaid (he gives it away for postcards), so your hardware may only marginally support it... but NO other program can match EAC's ripping capabilities. Period. End of story.
    http://www.exactaudiocopy.de
    Use the LAME compressor to make MP3's... with the EAC recommended settings, it's fast and makes VBR 192KB MP3's that sound WORLDS better than the 128KB crap Musicmatch or any other ripper puts out.
