Today (23/10/2004) i purchased 100 Ridisc 8x DVD-R from a local computer shop. They were specified as Ritek G05 and also Ridisc only use Ritek dye but to my horror DVDinfoPro reads them as TTG02. Has anyone else found the same discs on sale anyway?
Media code/Manufacturer ID TTG02
Format Capacity Not Formatted
Free Blocks 412352512
Free Capacity 4.38GB(4.71GB)
Book Type DVD-R
Media Type DVD-R
Manufacturer Rated Speed Unknown
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 5.9x 8112KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.0x 2770KBps
Write Strategy Speed 4.0x 5540KBps
2x Speed OPC beta 09
2x Speed OPC power 0A
2x Write Strategy field 1 15 98 89 90
2x Write Strategy field 2 88 80 00 00 00 00
4x Speed OPC beta 05
4x Speed OPC power 15
4x Write Strategy field 1 0C 0E 09 04
4x Write Strategy field 2 96 05 0B 0B
4x Write Strategy field 3 80 00 00 00
4x Speed OPC beta multi-pulse 09
4x Speed OPC power multi-pulse 18
4x Write Strategy field 4 14 97 88 85
4x Write Strategy field 5 B8 9A B8 83 00 30
4x Write Strategy field 6 00 00 D0 00 00
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
To your horror?
TTG02 is excellent quality 4x DVD-R media made by TDK in a CMC plant in Taiwan. Very good stuff.
The most you can really be angry about is the write speed. These are 4x discs. The RITEKG05 would have been true 8x media.Want my help? Ask here! (not via PM!)
@lordsmurf,
TTG01 is 4x media.
TTG02 is 8x media.
Both burn good at 8x on NEC ND-2500A/2510A/3500A burners.
Regards,
TerminalVeloCDCurrently own:
* ASUS CRW-5232AS 'QuieTrak'
* JLMS XJ-HD165H
* LiteON LTR-32123S, LTR-52327S, SOHR-5238S
* NEC ND-2500A@2510A, ND-3500A, ND-3520A
* Pioneer DVR-107D, DVR-108, DVR-109 -
That's what I get for both posting and watching the World Series at the same time.Originally Posted by TerminalVeloCD
Doh!
Dye-based vs metal-based: which will last longer?
By RedZone in forum Authoring (Blu-ray)Replies: 11Last Post: 11th May 2010, 22:30 -
Ritek RiData G05 vs RiData Pro Series - Anyone know the difference?
By DVantrease in forum MediaReplies: 5Last Post: 1st Jan 2009, 16:48 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 20:18 -
Color of dye on disks
By jbartosh in forum MediaReplies: 3Last Post: 25th Nov 2007, 18:15 -
Different dye coloration after burn (TDK DVD)
By xSimonx in forum MediaReplies: 2Last Post: 24th Sep 2007, 21:29
