  1. Hi guys
    I have a dvd -/+ re-rewriter. When I use dvd shrink to back up a disk, either fully ot in part, it plays fine in my stand alone dvd player. However, when I encode a movie and try to burn it, my dvd player makes squeeking noises and says "no play".
    I use TMPGEce to encode, and it used to work fine on dvd-rws. Since I got this new drive, it simply wont work for disks I author myself/ I have followed all the guides about encoding for dvd format, and it always fails.
    Anyone any idea where I could be going wrong? seems strange how backing disks up with dvd shrink works, but making my own doesn't anymore. I dont think its the media, as the dvd shrink method works
    Any help would be great
  2. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    you could try using a program like tmpgenc dvd author to help you out
  3. Tried using that, same problem still
    Anyone else want to try? <grin>
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    hmmmm..is there a mix up between pal and ntsc? have you tried your discs on a different dvd player?
    i dunno
