I need to join 2 avi movie files together using virtualdub but the resample rates of the 2 files seems abit different..so is there anyway that i can edit the resample rates to the same rate? thanks.
open the avi that you should resample
select audio->full processing
select audio->conversion and select the new rate
select audio->compression and use the same compression as in the first video(wav/mp3...)
select video->direct stream copy
save the new avi
then join the two avis.
How to resample the audio of a WMV file ?
By turbo20010 in forum AudioReplies: 22Last Post: 13th Jan 2011, 12:21 -
Nero Vision (edit:) Motion Adaptive Frame Rate Conversion
By sagat93 in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2010, 11:06 -
let the standalone do the resize (resample)?
By rebl in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jan 2010, 14:46 -
Export frame resample (PAL HDV)
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Jul 2008, 15:07 -
How do I edit the frame rate of a selection of frames in VirtualDubMod?
By manilow in forum RestorationReplies: 4Last Post: 21st Dec 2007, 22:12
