I am using tmpgenc pro 2.51
I have a "normal" mpeg2 file (ntsc mpeg) that I want to convert to a variety of other mpegs mpeg1 and mpeg2 diff bit rates fps screen etc.
My problem is when I try to open an mpeg file as a source in tmpgenc it does not accept it.
is this an issue fixed in a later version?
I have look in variuous tool areas and not found it so far.
simply put, I want to do an mpeg-mpeg conversion using tmpgenc. does that exist - I know in the tool section it is listed but I can't see how to do it.
Allen
Open the file in virtualdub mpeg2 or virtualdubmod and frameserve to tmpgenc. Look in the guides for info on how to frameseve with virtualdub.
Donadagohvi (Cherokee for "Until we meet again") -
Hi,you'll need this one:
https://www.videohelp.com/tools?tool=MPEG2_Codec
After installation go to
"Option"-"Environmental Setting"-"VFAPI plug-in" and there you
should see "MPEG-2 VIDEO Plug-In"
That's all.
Good Luck
viking -
Thanks for the answers .. I tried the seocnd one to ensure that I have an mpeg2 plug-in ...
Firstly when I look at the plug-in section I see that I do have .....
"cyberlink mpeg2 decoder" listed as built in.
When I run the program you reccomended it does NOT add in another mpeg decoder.
Again when I try to open the mpeg I get "the file XXX can not open or unsupported"
Any other suggestion.
allen -
Does your "cyberlink mpeg2 decoder" have a priority of one in the VFAPI plugin section?
It doesn't matter who you vote for. The government always gets in. -
sorry to answer myself ....
although the codec you gave did NOT work I found that this one
www.digvid.info/software/m2v_vfp.php
has one that works.
thanks for the lead ....
now I need to figure out how I can play with the params - when created a vcd file .. everything looks grayed out .. -
has one that works.
Open source video format conversion engine
By TrupsT in forum Video ConversionReplies: 2Last Post: 2nd Feb 2009, 07:32 -
Conversion of 2.35:1 Source to QT files
By ehmjay in forum MacReplies: 3Last Post: 4th Nov 2008, 02:55 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
Framerate conversion question - 30fps source
By Killer3737 in forum Video ConversionReplies: 17Last Post: 8th Aug 2007, 13:30
