There is a vertical shadow band (1 inch wide) moving from the left of my TV screen to the right every one second. The DVD player is Philips DVP630 connected to TV via SCART cable. This occurs 1) before playing, 2) while playing, 3) while pausing, 4) while in SETUP screen in the middle of playing. Both DVD and XviD discs.
If the unit is put into stand-by mode and put back on then the shadow can disappear but this doesn't always work.
The unit is also connected to a Compro VideoMate Live 2.0 via S-Video cable and there is no such problem on ComproPVR screen even while it's happening on TV screen.
Anyone with DVP630, DVP632 or DVP642 or any other player have similar problem? It can be hard to recognize but once you've recognized it, it'll always be there scanning your screen and it is very annoying.
Problem solved! The player isn't really connected directly to the TV but through an NTL set-top box (I completely forgot that)! The set-top box has to be put into stand-by while the player is on. I guess some sort of interference.
mplayer: window gets smaller when moving it off the screen
By adom in forum Software PlayingReplies: 0Last Post: 26th Jul 2011, 14:34 -
Screen Video Streaming scroll to left
By n33 in forum Video Streaming DownloadingReplies: 2Last Post: 14th May 2009, 09:22 -
A stripe across the left border of video screen
By Omid in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2009, 08:42 -
Moving a specific line up the screen????
By Absorbeo in forum SubtitleReplies: 3Last Post: 2nd Dec 2008, 16:20 -
Vertical band moving across screen - DVD/HDD recorder
By wizbru in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2007, 02:20
