Good morning everyone.
Although I haven't really done any real-world speed testings, but I'd
like to know which SW does quickest for when I'm in a hurry for AC3,
as I seem to be in, a lot these days.
I have two questions:
Using my TRV22 / ADVC-100 devices for capturing my VHS movies with..
* What or Which software app can extract the WAV from the captured DV
.. file, and export it to an AC3 file ??
* I like my audio settings at 192k as a minimum standard for a DVD
.. (vhs -to- dvd) project.
Now, perhaps speed is not a factor. I don't really know this, (if you
read my first para above)
* And, after creating my AC3 file, how can I play it, just to be sure
.. it has ben created (with sound) ??
.. I did try winamp, but it was silent. Anything freeware'ish ??
(I was thinking of re-coding my own gui for an AC3 import (since I lost
most of my delphi code snips I aquired over the years, due to a crash
some months ago) - but I've become a little lazy'er since that incident)
My specs:
.OS: Win98 Gold (not SE)
CPU: XP-1800+ w/ 128mb ram
VCR: JVC S-VHS HR-S3910U
Thanks in advance guys,
-vhelp
Install ac3 filter and you can play ac3 with any player.
ffmpeg is a fast ac3 encoder, you can use my ffmpeggui but it isn't 100% dvd compliant though. -
Thanks for the tip Baldrick
Actually, I am using your gui app :P
I was just wondering if there were something that did it faster, but that I and
others may not be aware of it.
I will try and burn an short DVD authored project (with AC3 audio) and post
back here if it worked or not. My test source is a widescreen VHS of the
movie, Star Trek Inserrection (IMO, was better than Nymisys) ..sorry
for my spelling. Anyways.
Before I finish.. do you have a prefered area to post suggestions on this app of
yours ??
Thanks again,
-vhelp
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Encoding wav file to ac3 specification
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 15th Feb 2010, 23:40 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 15:44 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 07:18
