Has anyone tried this program lately?When it was first released last spring,it wouldn't work if you deselected titles or audio.There tech support even admitted there were problems.I notice the website has been updated.At 11.9 MB,it would take me 2 hrs. to download before i try it again.
Brad
bmiller,ont.canada
HI,
I have just tried backing up a couple of movies using this and they copied fine and play back ok on my PC. The only trouble is they won't play back on my stand alone DVD player's. When I insert them the dvd player tells me there is no disk. I used this software a few months ago but uninstalled it along with other stuff after a few PC probs. It did the job very well before but now I don't know what is wrong. I am using DVD-R 4x discs. I have anydvd running on my PC and have two dvd-rw's. One is a Sony DVD-RW-DW-14A and the other is MSI-DVD-RW-DR8A2. Both are dual formats. I use this software as it is just a matter of three clicks of the mouse and its away. Could anyone tell me why they don't play on my stand alone DVD player
Cheers
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Intervideo DVD Recorder in Vista?
By jubbely2 in forum Capturing and VCRReplies: 0Last Post: 13th Jun 2008, 12:40 -
DVD Fab Platinum to HD
By mblanco2000 in forum DVD RippingReplies: 7Last Post: 2nd Mar 2008, 15:50 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
intervideo dvd
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 10:37
