Hi Chrissyboy
Looks good, but a couple of problems at my end.
When making a menu, you cannot scroll around the screen and I accidentally put an object off the visible screen and can't retrieve it.
I think some kind of scrolling of the window is needed.
Also maybe a "select all" button in the menu maker.
Cheers
Monster
Duly noted.
Have you tried "Select all" with the mouse - draw a bid rectangle to cover all the objects.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Can't drag a big rectangle and enclose the object, cos the object was not visible and the marquee doesn't go beyond the screen edge, or cause the window to scroll.
Hope this helps with the development.
Monster -
Ok. I see what you mean. Thanks.
Yep. Got the same problem (as a result of not fully appreciating what the effect of the alignment buttons would be when I had 10 buttons). Perhaps a "Reset Menu" option would help.
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 09:58 -
DVDFab 3.1.4.5 Beta
By devilcoelhodog in forum Latest Video NewsReplies: 0Last Post: 15th Jul 2007, 01:42 -
Beta 2.5 download?
By hordak in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2007, 04:59 -
svcdvd2dvd 2.5 beta
By bighun in forum SVCD2DVD & VOB2MPGReplies: 24Last Post: 13th May 2007, 02:46 -
Beta 2.5 first impressions
By mesaboogieman in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th May 2007, 18:25
