After a year and a half of burning all my videos onto CD's using Videp Wave I finally got my hands on Premiere 6. No significant issues yet. My question is this: What file format is recommended to capture in? HD is not an issue so I have always captured AVI. Do I have option on the file format that I can output? Obviously I'm still learning the basics with adobe. i rendered a short clip (3 min.) and noticed that it is not avi anymore. Adobe called it "Adobe Premiere Project". I would like the best quality possable to burn with. Unfortunatly I burning with Adaptec so I can only burn vcd vrs svcd. My last question (this time) what are my options for file format with adobe and what are my advantages with each.
Thanks much
hmmm not in front of my 'puter right now - this is from memory.
You need to select "EXPORT TIMELINE" option . The select "MOVIE". From that select your codec. Codec's offered will only be the ones in the plug in folder.
OR get "AviSynth" and frameserve to TMPEGEnc (my method)
<font size=-1>[ This Message was edited by: holistic on 2001-11-27 11:48:39 ]</font>
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 17:52 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
File format not supported on mp3 adobe premiere cs3
By afrojavi in forum EditingReplies: 2Last Post: 26th Apr 2010, 06:35 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
