  1. If you are looking for a good multi-dvd binder, I used the panavu model from
    http://www.napcousa.com/panavu_products.asp
    look in the middle of the page - the $16 version is good (Folio Creased Back Style) - holds a lot of DVD's and if you are doing large sets for someone, it is very good and not too expensive.
    you can order direct from them and they can do low quantities too...anyway, I just wanted to put this out there since I looked around for a while and this was the only thing like it I found...
    if you do any type of large quantity, they can custom deboss it for you as well (and I think even a different emboss for lower quantities)....
    anyway, these are highly recommended....
    fwiw, I don't work for them, have stock, none of my relatives work there, etc. but these were relatively unique and worked out well so I thought I'd pass it along
    keywords: DVD Case
    "As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
  2. Why waste your money when you can get more bang for your buck at computer geeks. 288 disc binder for only $9.95!!
    http://www.compgeeks.com/details.asp?invtid=GEEKSTOR-CASE-N&cat=CAR
  3. yeah, actually my post was for a different purpose...intended for someone creating a dvd set for a customer where you want to give a professional looking binder for up to 40 dvds.
    there are a ton of those briefcase ones like you show that you can carry around your own set of 288 dvds.
    This is where you made some dvd's for someone, more than you want to put in individual or quad cases.
