Hey there,
I have a 29.970fps DV file. It plays perfectly.
When I use TMPGEnc to encode it at 29.970 fps, the sound is always out of sync with the picture.
Can anyone tell me what's wrong? THis isn't the first time I've had this...
Edit: This is also happening with ProCoder, which means I have no other encoding options... why would the file play properly but mess up when encoding? Is it anything to do with my file being 29.970fps and the DVD encode options being 29.973?
Nope, there's absolutely no problem with the original file. In fact, in the encoded final product, it slips further and further out of sync as time goes on.
Ok, if it slips further and further, this is serious because there is no easy way to solve the problem. Usually it is something to do with the original file, something that your encoders don't like.
Editing can cause de-sync, a bad capture causes it, or there could be a few frames at the begining or somewhere else that can cause it. Finding out the culprit will be hard without more info about your process, so you are probably on your own on this one, sorry.
Out Of Sync sound in mpeg2
By JN in forum Video ConversionReplies: 2Last Post: 20th Nov 2009, 03:52 -
Sound out of sync
By ssaamm in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2009, 10:19 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
Slideshow with sound in sync
By tin2tin in forum User guidesReplies: 0Last Post: 18th Jun 2008, 04:07 -
Sound out of sync
By bananadon in forum DVD RippingReplies: 9Last Post: 17th Oct 2007, 09:31
