Ok, alright, may sound like a stupid question... since my player plays both NTSC and PAL I was wondering if there's a difference in VCD quality when comparing the two systems.
Here on the comparison charts between the mpeg softwares the system chosen is PAL... So, are the results in PAL actually better than NTSC?
yes
They both have problems.
but it does have better resolution and color ..
but the flicker drives me nuts"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
