How do you delete the disc memory in DVD shrink? It keeps the discs done in memory and won't let me redo them with different settings. Is there some way to delete the memory and start over again with different settings.
The only thing it won't let you repeat is the deep analysis phase. That's because once it's performed, it's unnecessary to perform it again. However, if you still want to delete the memory, it is possible. Look inside the subdirectories of the Krpobe program folder, you should find the info there.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Hi all.
Just in case, I'd like to add this folder is hidden.
Windows Explorer >> Tools >> Folder Options >> View >> Hidden files and folders >> Show hidden files and folders. -
As an extra
this data on my machine running XP home is kept in
C:\Documents and Settings\All Users\Application Data\DVD Shrink
not in your user name but in the all users folder.
yes it is a hidden file.
each file betwwen 2.5 and 8 kb, but each 32kb size on dsc.
regards
dvd shrink error out of memory???
By carlos28355 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2014, 00:04 -
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
DVD Shrink error - Out of Memory
By xoADAMox in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2011, 10:32 -
DVD Shrink-short of memory
By Mållgan in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 07:02 -
DVD Shrink not releasing memory when done?
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2007, 11:12
