    Aug 2002
    I had a Mpeg2 file that I demuxed because I want to use uncompressed audio when authoring a DVD for compatability reasons.
    I use the M2V file for the video, then I take the original MPEG2 & put it through VirtualDub & extract a WAV file. I then run that through Audacity to remove some low end hiss.
    When I select the WAV file in Tmpgenc DvdAuthor it rejects the file beacuse it is 44.1 instead of 48hz audio.
    How can I convert the audio from 44.1 to 48hz? ( I was using hardware MPEG2 to capture the video & the only audio option was MPEG layer II)
    thanks
  3. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    Goldwave I love it. Use it to convert 32KHz audio to 48KHz audio all the time. Also, I love the Time Wrap feature.
    Aug 2002
    Thanks but right now I'm looking for freeware.
    I just did a somewhat roundabout way by converting the WAV to AC3, then from AC3 back to WAV. That worked.
    I also look at that ssrc program.
  5. Why not use the filters in VirtualDub, then just select Audio>> Conversion>> Sampling Rate>>48000 hz. Then save WAV. Or extract in VDub first, then run thru Audacity. Good luck.
    Pull! Bang! Darn!
    Aug 2002
    Thanks, never played with VDub enough for audio issues - did't realize it could be done that easily.
  7. Seeing as you were in Audacity anyway you could have just changed the samplerate there!!
