Do you have any idea about the reason I m not able to capture using resolutions like 352X576 or 720X576 (DVD PAL) but only 352X288 (or less) ?
I was thinking that the problem was related with PowerVCR settings, or something having to do with PowerVCR in general, but using mainconcept 1.4.2 I had the very same problem. The messages are not the same but say the very same thing
PVCR---> ” S0028 : Unable to run caprure graph”
and Mainconcept ---> “error during capture!”
Thanks in advance
Results 1 to 1 of 1
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
