Please refresh my memory.
Which program(s) will be able to rip the files from a VR disk?
OS is Windows 2000.
I have Cyberlink Power Producer that came with my DVD drive.
I used the JVC to timer record some programs.
In the past I've always recorded in Video mode and had no problems using TMPGEnc DVD Author to rip the files.
Thanks in advance.
Cyberlink Power Producer has always worked for me, but I have XP not 2000 so I don't know if there would be any difference.
Power Producer is just plain better than TMPGEnc DVD Author for ripping any DVD (whether Video or VR mode). TMPGEnc seems to sputter around just reading the directory and you can only rip 1 file at a time, then you have to read the directory again and rip another file, etc. With Power Producer it reads the directory quite fast and allows you to check mark all the files you want to rip all at once. -
DVD-VR disk is formatted in UDF 2.01 which is not supported by Windows 2000. Install latest version of Nero InCD or Nero InCD reader will allow you to read the VR disk.Originally Posted by broadway
Then use other programs to rip the VRO files.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
