i looked on the guids and i couldent find anything for this
any ideas?
Results 1 to 19 of 19
Hello,
Maybe these might help:
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=WMV+to+DVD&h...or+List+Guides
They're under wmv to dvd. I'm sure there must be a relevant conversion step in one of them. Good luck
thanks il look into that now, but i dont need wmv to dvd i only need to avi cause my dvd player plays avi
im quite new to the whole converting and buring thing so i wonder if you could tell me if converting to svcd or vcd (dvd format) would get me longer? -
i just tryed Stoik Video Converter and had no joy is there anything basic i can use even though that seems pretty basic
it seems to only work the wrong way around, i tryed input file C:\~filename.wmv and output i put a none existing a file *.avi and i get the message cannot open input file
i tryed it the other way around and it worked EEK
help! -
In this case I would recommend TMPGEnc XPress. If you choose AVI Output you can select your DivX/XviD/MP3 codecs and XPress automatically uses the same resolution and framerate as your WMV file.
I know it's also possible to output to AVI with TMPGEnc Plus but if I remember correctly it didn't automatically keep the resolution/framerate of the source, so with Plus there's more configuring involved. With XPress it's easier. -
just tryed that now and it says cannot open or the file is unsupportedOriginally Posted by glockjs
it just wont accept my .wmv as the source eather am i missing something?Originally Posted by erratic
https://www.videohelp.com/tmpgenc.htm#problemsOriginally Posted by metadethicaIf in doubt, Google it.
TMPGEnc XPress natively supports source files in MPEG-1/2 format, unprotected DVD-Video VOB, Windows Media Video®, uncompressed AVI and QuickTime® files so I have no idea why it doesn't accept your wmv file. It certainly opened and converted the wmv file I tried. Is the Windows Media file reader checked in Option -> Preferences -> Input plug-in setting?
If you want AVI I would try the last version of virtualdub to support ASF: http://files.digital-digest.com/downloads/files/virtualdub/VirtualDub14c-asf.zip - If it won't open the file, you might try changing your file extension to ASF.
For MPEG-1/2 I would use TMPGEnc. Make sure you read https://www.videohelp.com/tmpgenc.htm#problems as the file unsupported error is pretty common and easily fixed.If in doubt, Google it. -
that link dident work, but i looked around and finally found only to get the error "ASF file support has been removed at the request of microsoft"Originally Posted by jimmalenko
Try VirtualDub 1.3c -> http://www.divx-digest.com/articles/asf2avi.html
http://www.afterdawn.com/software/video_software/video_tools/virtualdub_1_3c.cfm
But VDub 1.3c can't open my wmv file, TMPGEnc XPress can. -
this just gets worse and worse, i installed the MS MPEG-4 VKI Codec and virtual dub 1.3c when trying to open my *.ASF i get "ASF: illegal object flags 0a in packet at ad0 packet size = 16a8, pp = 12, send time: 0:00"Originally Posted by erratic
OK, let's go back to the MPEG route, shall we ?
Try the tips listed at https://www.videohelp.com/tmpgenc.htm#problems.
PS sorry about the bad link - it is the link from this page.If in doubt, Google it. -
i did this befor changed the DirectShow Multimedia File Reader priority to highest which was the only thing related to what im trying to do in them that tips section and it hasent helpedOriginally Posted by jimmalenko
I get a similar error with VDub13c. Maybe you can check out these tools.
http://www.brothersoft.com/Multimedia_Graphics_Video_Conversion_Fx_Video_Converter_20561.html
http://www.mp3towav.org/wmv-to-avi.asp -
i tryed wintoav and it dident work(streaming error) so i give up, thanks for all your help anyway, im going to bed
How to change AUTHOR, TITLE, ETC. of mov, avi, mpeg, wmv ??
By weezer76 in forum EditingReplies: 4Last Post: 28th Sep 2010, 17:02 -
converting mpeg to avi or to wmv
By stevenr2 in forum Video ConversionReplies: 4Last Post: 11th Jan 2010, 16:56 -
How can I convert WMV to AVI or MPEG?
By betlysmith in forum Video ConversionReplies: 6Last Post: 25th Nov 2007, 02:02 -
Hi8 to AVI MPEG WMV archive strategy
By hgdb in forum Capturing and VCRReplies: 4Last Post: 5th Sep 2007, 21:17 -
Best way to re-encode 13GB DV file to 4.5GB avi/mpeg/wmv
By ColKurtz in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2007, 22:59
