I'm trying to copy a disc with series on it, it's about 3 hours long plus menus. When I load it into DVD Shrink it comes up as 6+ gigs, but the meter is only about 1/4 used and it says it needs no compression. This can't be right. I tried running through decrypter first, same thing. What am I doing wrong.
you could try to re author to get all the video and forget the menu's. sometimes the file structures do funky things. or try another backup program.
What's your target size in Shrink preferences? Sounds like Shrink is using a target size of ~25 GB.
You got it, that was the problem. I had an extra 0 on the end of the size, thanks.
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 08:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 21:28 -
DVD Shrink- Reauthoring Problem
By MPO in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 12:42 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 09:09 -
DVD Shrink problem
By lapetite_66 in forum Newbie / General discussionsReplies: 27Last Post: 10th May 2007, 11:21
