hmm, my computer gets a total damage und shut down after 14% encoding. anybody here with the same problem?
further svcd2dvd rc1 don`t start, whats wrong ?
Results 61 to 67 of 67
If RC1 doesn't start, email me for a new key. Does your PC shutdown with all versions of SVCD2DVD? What are your PC specs?
thx ChrissyBoy
following problems i have
before i installed beta 8 all works good.
after installing beta 8 my svcd2dvd 1.51 didn`t work more and make many problems. after installing rc1 my computer shut down after resampling. with version 1.51 i got an ffmpeg error and program shut down.
with rc1 i would beginning a new test and after 14% my computer shut down totally.
my pc specs are windows xp sp2, AMD Athlon XP, 1659 MHz (12.5 x 133) with 576 MB (SDRAM) -
are v1.5 & v2.0 are having a problem with the same file? Can you identify a file that works ok with v1.5 and then try it with v2?
I have sent you an email. Thanks.
Hi,
I just got this V2 software a few days ago. I have to say it is a fantastic bit of software. If I may make 2 suggestions...
1st, I would of liked to have seen an option on the program 'shut down computer when done'.
2nd, It would be nice to be able to tell the application to fit the output folder into a 4.7Gig DVDr. I recently put 3 Svcds onto one Dvdr and it was 5gigs in size. I had to run the Output folder through 'Shrink Dvd' to reduce the size of the dvd
DVDFab Media Player 1.0.0.1 beta has been released
By Kerry56 in forum Software PlayingReplies: 3Last Post: 13th Feb 2014, 04:00 -
New HCenc beta released
By hank315 in forum Video ConversionReplies: 4Last Post: 22nd Sep 2009, 18:36 -
New beta of HCenc 0.24 has been released.
By freebird73717 in forum Newbie / General discussionsReplies: 1Last Post: 18th May 2009, 03:00 -
hank315 has released a beta version of HCenc 024
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2008, 11:20 -
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 10:58
