Just like to say, "Excellent work ChrissyBoy"
Results 31 to 60 of 67
Chris,
I will try some more extensive testing tonight and tomorrow but I have encountered the following issues so far
AVI to DVD
When I converted a single AVI to DVD, and put a single vts item as a menu, the movie played, but periodically it would "stick" on an individual time, flicking about to times one second above and below for a while and then continued briefly before happening again. It seemed to try and replay a short element over and over again, much like a scratched cd tries to do.
(S)VCD to DVD
I tried using v2 to do a dvd without a menu and it still wouldnt play on my standalone. It seems to be able to move between the titles and chapters if I skip forward through chapters etc, but it wont actually play anything. Im afraid I dont know the cause of this so cannot advise anything further on the subject.
If I try to do the same on v1.5, it plays correctly on both standalones and pcs. I dont think my standalone is likley to be the main issue as I can play DVD-R I create in other ways as well as purchased DVD-R movies.
Let me know any testing paterns you would like me to try if you need more info, also if you need further descriptions of what I encounter, please advise and Ill try some more.
I have not had a "perfect" DVD produced yet from v2 as playing on my standalone seems to not work correctly.
I will check the AVI disk later to see if that skips on the pc.
Let me know any details you want or need on any of the above.
Thanks -
Have a look at https://www.videohelp.com/forum/viewtopic.php?t=244555 and let me know if this is resolved.
Thanks.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks.... I'm a big fan of yours too!Originally Posted by AnAsTaCiASVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi Chris,
I made 2 DVDs with v2 and while they work fine on the PC they wont play in my standalone player. Well to be more accurate, the menus work, I can select and start a movie, but after a while it skips around, and fast-forward/rewind causes it to screw up - it skips and jumps over a short loop. I re-converted and re-burned with 1.5 and it works perfectly. I haven't tried 2 since then.
Regards,
Scott -
Which version?
Sorry, I missed the Beta 5 update. Have downloaded it now and will try it out on the next project and let you know of any problems.
Cheers,
Acott -
try Beta 7.... The issue you cite was resolved...
I have downloaded Beta 7 (build 2.1805.29370) but when i click on the settings tab and click on burn i get this JIT error message which i never had in any of the other beta`s,
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at x3284ccece41ee22b.x067e7d569898d5a4..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.x3bae72ab2c7b4 5fc(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.SideBar.93(BaseItem 331)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1805.29370
Win32 Version: 2.0.1805.29370
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 4.6.0.0
Win32 Version: 4.6.0.0
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
SVCD2DVDLib
Assembly Version: 1.0.1797.35130
Win32 Version:
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
Microsoft.VisualC
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
Interop.NEROLib
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files/Badgersoft/SVCD2DVD%202%20BETA/Interop.NEROLib.DLL
CustomMarshalers
CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog. -
Here is my guess. You have some software from VSO installed - but not CopyToDVD. Is this the case?
VSO: http://www.vso-software.fr/
CopyToDVD
BlindWrite
VSO PhotoDVD
VSO DivXToDVD
Do you have anyof these installed? i.e do you have the following registery key:
HKEY_CURRENT_USER\Software\VsoSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
yes i have that registry key.Inside the folder is copytocd and one called Patin Couffin.
Pretty sure i dont use these so i am just having a search throught the pc,what do you suggest now please. -
Well it is my fault for not checking the registry properly. I will fix that in the next release.
Can you add a new String value to the VSO key called CopyToDVD with no value? This should resolve it but like i say i will get it fixed.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have just deleted the folder called VSO and have deleted the copytocd from the registry and i dont use them should it be ok now.
yes
well if you delete the VSO key from the registry.
no worries. Thanks for bringing it to my attention.
Originally Posted by SlytNot hassling, just reminding you incase you forgot (Im guessing the beta stage is nearing a close you see)Originally Posted by ChrissyBoy
SlyT
PS - Is there a way of compressing the converted avi dvd_mpeg so you can get more than one on a DVD ? - I know it was discussed at some point but cannot remember whether it was going to ever be implemented.
Keep up the good work dude !! -
I'm using beta 7 and noticed that someone else got the same exact error I got:
Type: System.InvalidCastException
Source: System.Windows.Forms
Message: Specified cast is not valid.
InnerException:
StackTrace: at System.Windows.Forms.Control.MarshaledInvoke(Contr ol caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at System.Windows.Forms.Control.Invoke(Delegate method)
at x3284ccece41ee22b.xd3764d4f1e921081.x24919c2ff8f0c 9b2()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
Same numbers as the other poster. I was able to convert the AVI file up to 99.5%, where it hung with the above error.
The audio_ts and video_ts folders were created and I was able to burn the vob files with no problem.Dave -
Thanks for the info. I think it is a windows focus issue. Was the SVCD2DVD window minimised or hidden at this point?
No, in fact I had just started SVCD to convert the .avi file and then burn it, and I left it as a full window.Originally Posted by ChrissyBoyDave
hi all
after using svcd2dvd for a while thought i would give the beta v2 a go,however i cant even get prog to run keep getting error >
Type: System.Runtime.InteropServices.COMException
Message: Invalid access to memory location.
InnerException:
StackTrace: at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.AxHost.EndInit()
at x3284ccece41ee22b.x2f5590cb48bb0c53.x85601834555fb 7d5()
at x3284ccece41ee22b.x2f5590cb48bb0c53..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
any help appreciated
regards jay -
k forget about the above post sorted that part out.
however i now get internal error message ,saying there is an error registering the program please inform the author.
any ideas ???
regards jay -
will the bin rip become automated before final release mate? by the way great tool! best £10 ever spent
jd1970: Just try it again. It will work.
lordc007: I shall be looking at various options on this and posting a RFC.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi Chris,
How difficult would it be to add more than one level of menus so that selecting a menu item will either start playing a VTS or take you to another menu screen?
For example I have made a couple of DVDs of TV series where I can fit 3 seasons/series on one DVD, each consisting of 6 episodes. It would be great if I could use the root menu to select your season, which would then bring up another menu listing all the episodes for that season.
Or how about an option to use .bmp graphics for menu items in place of text - one graphic for each of the 3 states?
Great job mate!
DVDFab Media Player 1.0.0.1 beta has been released
By Kerry56 in forum Software PlayingReplies: 3Last Post: 13th Feb 2014, 04:00 -
New HCenc beta released
By hank315 in forum Video ConversionReplies: 4Last Post: 22nd Sep 2009, 18:36 -
New beta of HCenc 0.24 has been released.
By freebird73717 in forum Newbie / General discussionsReplies: 1Last Post: 18th May 2009, 03:00 -
hank315 has released a beta version of HCenc 024
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2008, 11:20 -
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 10:58
