hi im wondering how do i convert ex .mpg move to divx. how do i setup the converter program so i get sound to?
This is what it can do
File type Avi, ASF, MPEG,
Video Type Divx 3.11, 4.0, 5.x, Xvid, Iso MPEG-4 SP
Audio Type MPEG 1/2/2.5, layer 3
Video Bit Rate Divx 5.x, Xvid : Maximum 1.5 Mbps
Divx 3.11 : Maximum 500 Kbps
Audio Bit Rate 8 Kbps - 192 bkbps
Resolution Divx 5.x, Xvid : Maximum 640*480
Divx 3.11 : Maximum 352*240
Vide Frame Rate Supports Maximum 30 fps
can eney bodey pleas help my
quicktime pro should be able to do that, just open the mpeg and go to EXPORT and choose DIVX
you can also use the all powerful ffmpegx to do what you want
cheers -
what is wrong when im using quicktime pro when im exporting and when im runing the move i haw made i dount get eney sound
Originally Posted by galactica -
sometimes that happens, just demux your .mpeg and then combine the audio with your converted .avi file
Im New Whit converting i cant noting about it
can u pleas explain 4 my how i setup ffmpegX so i can convert .mpeg move to .avi the setings most be
whit in thes info
i haw traid to convert move whit ffmpegX but somting is olways wrong my player is saing cant play this file probebley somting to do whit the setings whit ffmpegX. but whn im using HandBrake it works grate but HandBrake can onley do dvd to avi i wanto haw mpeg to avi or avi to avi but whit sheng sais so i can whots it on my player -
well you could always convert it to dvd then to avi
look to the tutorial list [sticky] in the main forum, you will see how to do lots of conversions
for your quest, i would open .mpeg in quicktime, export to .avi
then take teh original .mpeg drag/drop onto bbdemux to get the audio file out of it, open the audio file in quicktime.
next i would mux the .avi and the audio from the mpeg using ffmpegx's mux option under tools tab
recording tv show hellp
By tim37 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 25th Apr 2014, 20:07 -
Confusion Among Formats & Codecs (Converting DVD for HDD/PMP Use)
By sirryan in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 14:42 -
Ned a new dvd player mostly for divx..
By sumik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th May 2008, 08:23 -
Ned help saving this particular video file
By wetcamelfood in forum Newbie / General discussionsReplies: 5Last Post: 7th Feb 2008, 20:07 -
Xvid on Iriver X20 - Flickering
By kidcash in forum Portable VideoReplies: 2Last Post: 8th Jan 2008, 04:43
