I was going to split the cable TV signal coming into my computer room so I could capture TV on the computer. I thought it would be wise to hook up an amplifier instead of a simple cable splitter.
Well after hooking everything up the cable TV signal was extremely fuzzy. So I unhooked it and put things back they way they were and now the picture is fuzzy on ALL the TVs!![]()
Did I blow something up?![]()
Anyone have any ideas?
Thanks in advance!
Results 1 to 10 of 10
"The name on the front of your shirt is more important than the name on the back"
Kurt Russell - Miracle -
Sounds like you created multiple RSG devices*.
What kind of an amplifier was it?
*Random Smoke Generator -
It was a RadioShack Two-Set Cable TV Amplifier.
That should have been safe enough. It's not like you used a 500W linear ham amp or anything. I probably would have done the same thing you did.Originally Posted by tmaxwell2435
It's probably a bad coaxial cable connection somewhere. Maybe you have an open ground on the shield and it's not making good contact with the connector. Check that and if you have some short patch cables, try wiggling those to see if it's an intermittent. -
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
yaeh ....if all your TV are getting the snow ...go to your outer-most source and work your way in to your home
Process of elimination. Sucks, I know.
Thanks for the input everyone.
Sounds like there is not an easy fix.
It's easy if you find a loose or bad cable. Don't give up before you check all the cables. Start with the easiest ones to get to and work back from thereOriginally Posted by tmaxwell2435
Hello,Originally Posted by Capmaster
Maybe it's a new cable protection scheme like Riaa to stop people from capturing to pcs!!!
Kevin
joking - good luck!
Cheap Boom Kit/GL1 Light/Shotgun Mic
By surfera007 in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2010, 12:30 -
Video Amplifier or not
By mysts in forum Newbie / General discussionsReplies: 6Last Post: 11th Jan 2009, 09:15 -
Video Amplifier - What's Your opinion?
By therock003 in forum Newbie / General discussionsReplies: 17Last Post: 8th Jan 2009, 20:25 -
Amplifier and Speaker Question
By tarasha in forum AudioReplies: 4Last Post: 22nd Aug 2007, 09:15 -
Make a Microphone Boom Pole for $15
By Soopafresh in forum DVB / IPTVReplies: 1Last Post: 29th Jul 2007, 13:43
