I was wondering if someone would have a suggestion for me to streamline disc processing.
When I am creating a DVD with toast, sometimes I will first make a disc image to see that the DVD files function properly. I then use Toast to mount the image and see that DVD player fires up and that the files are all intanct before I burn to disc. I usually unmount the data files to make sure DVD player picks the correct image. Is there a way I can then use the mounted disc image to burn directly to disc?
If I understand the question correctly the answer is no. The easiest and fastest way to burn a Toast disc image file is with the disc image setting in the Toast Copy window. It doesn't matter if it is mounted or unmounted.
Originally Posted by ruggerjvd
So you need to use Toast anyway. And if you're using Toast, why burn from the mounted disk image rather than from the disc image file?
I also often make disc images with Toast before burning to DVD. I just don't understand why you want to burn from the mounted image. -
if i read this right, you can!
you are simply saving to HD as image and then mounting the image instead of burning directly to the disk
if the playback is acceptable to your standards, there is NOTHING wrong with unmounting the image and then burnign the image
CAUTION: make sure you are making a DVD-ROM UDF image, but selecting that option in toast, otherwise the burned image will NOT play as a dvd -
In what Galactica said, yes I can vouch for this.
I have on items where on training DVDs where
there is no copy guard protection, I have saved
that disc to disc image to HD, and then
at a later date, re-mounted the disc images
to consolidate 2 dvds to one using DVD2ONEX."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I still don't get it. What are the data files that ruggerjvd unmounts? Why would DVD Player possibly read data files instead of the VIDEO_TS folder in the mounted image?
ruggerjvd wants to burn a mounted disc image directly to disc. One way to do this is drag the VIDEO_TS folder from the mounted image to Toast. But why do that when the disk image can be burned directly from the Toast Copy window?
Please clarify, ruggerjvd, I feel like a complete idiot because the others seem to get what you're asking and it now makes even less sense to me.
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 14:28 -
Important question about burning with Toast
By mac&me in forum MacReplies: 1Last Post: 24th Nov 2010, 18:47 -
Burning a DVD ripped with MTR without the Toast application
By FilmLabAsst in forum Newbie / General discussionsReplies: 1Last Post: 20th Sep 2010, 11:58 -
Problem: Final Cut Pro, taking a 24p HD Blu-Ray and making a DVD with Toast
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 22nd Apr 2010, 09:03 -
burning a DVD in Toast
By lalilyman in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2010, 22:11
