Convert the audio to wav using Virtualdub or Goldwave,
www.videohelp.com/virtualdubaudio (Virtualdub)
or
www.videohelp.com/forum/userguides/160649.php (GoldWave)
and then in Tmpgenc open the video first and then the separated wav file. Okey? Done. No more questions. mmkey?![]()
Usually means you used the wrong sample rate. DVD audio must use 48 khz sample rate. But it might also mean someone used mp3 or Ogg audio instead of Mpeg-1 layer 2 to encode the audio. Follow Baldrick's directions, convert the mp2 audio stream to a WAV, if necessary convert sample rate -> 48 khz using Goldwave or Sound Forge or Cool Edit Pro or whatever, then encode the 48 khz WAV file using Tmpgec.
HELP! I used Virtualdub to convert the audio to a wav file and the sample rate is 48 khz. But there was no sound when I previewed my movie in Tmpgence, everything looks fine except there's no audio! Can someone please help me? (I'm burning it to a DVD)
Yes ... Mr .... Garrison ....Originally Posted by Baldrick
Why don't you just throw a link to https://www.videohelp.com/tmpgenc.htm#problems ?
This is why stickies are normallyOriginally Posted by usyagitntn
You might have more luck if you start your own thread about this problem. Have you definitely loaded your video source, then loaded the WAV as the audio source ?If in doubt, Google it. -
Hi, I have just got TMPEnc and when I load up the avi its fine in video but when I try to load the extracted WAV file in audio it doesnt see it, help.
"It doessn't see it, help."Originally Posted by SilverDales
Any more specific details, such as an error message ?
I'd say that the extract to WAV went amiss somewhere. Here's two ways of doing it:
https://www.videohelp.com/guides.php?guideid=837#837
http://members.dodo.net.au/~jimmalenko/ExtractAudio.htmIf in doubt, Google it.
multiAVCHD runtime error when trying to convert any video file
By i am x in forum Video ConversionReplies: 5Last Post: 25th Jun 2011, 22:53 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 22:02 -
Splitting long (hours) MP3 files by sound breaks
By lostinlodos in forum AudioReplies: 3Last Post: 19th Mar 2009, 22:37 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 11:01 -
Tmpgenc Express rendering real video, result no sound
By pcb in forum Newbie / General discussionsReplies: 0Last Post: 31st May 2008, 15:17
