  1. I converted a video clip from XVid mpeg 4 to MPEG1, only to find out the audio could not be converted or something, there is no sound in converted MPEG1. I checked the avi to see what codec was used for audio and find out it was "ac3 (0x2000) Dolby Laboratories, Inc" I have 2 codec "AC-3 ACM Decompressor" and "AC3 Filter " installed on my PC, but somehow TMPGenc could not get right decoder.
    What could be wrong... any advice will be helpful. Thanks.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Never had any luck with AC3 and TMPGEnc.
    Load AVI in Goldwave. Save wav. Use AVI as video source, use wav as audio source when encoding in TMPGEnc.
    /Mats
  3. Had the same problem and solved it this way: extract the audio from the Xvid, load the wav into TMPGEnc as the audio source and go for it. Works everytime for me.
  4. ............or you could just use a simple Avisynth script and frameserve to Tmpgenc. That will downmix the ac3 to uncompressed PCM and should work OK
  5. Member Nasdaq's Avatar
    May 2003
    In front of the monitor.
    Thanks for the advice. I was having the same problems getting TMPGE to work for me, too.
    Never argue with idiots.
    They just wear you down and then beat you with experience
    - Unknown
