i have an MSI@nywhere card in my system. however when i capture, even at best quality, the video has a little fuzziness to it, like a static pattern . Quality is sort of like dubbing a VHS on EP mode.
Is that the best it can capture?
i have the same card and it captures fine,how are you capturing?
its not even when i record. just watching the tv its like that. its not bad enough to distort the picture but i see wavey line running thru the picture sometimes. very lightly.
This doesnt appear on my tvs so im wondering if im doing anything wrong here -
Originally Posted by johns0
Do you have that problem? -
My remote worked once and hasnt worked since,i think its poor quality control on that issue,as to the distortion you see on the screen can be a weak signal coming from the cable in or computer generated noise.Does the picture look better when you use composite video in from the vhs using a good quality signal?
there is no vcr/vhs hooked up here, i just have cable in, and s-video in from my ps2.
I guess its certain channels. mainly the national channels believe it or not. majority of the cable channels work excellent.
Slight prblem with noise.
By Jimbo1 in forum Video ConversionReplies: 1Last Post: 25th Jun 2011, 08:57 -
Slight Hauppauge HD PVR Issue
By octaneflame in forum Capturing and VCRReplies: 4Last Post: 10th Feb 2011, 16:46 -
Fuzziness when Convertin HD WMV to AVI using FFmpegX
By BassJunkie in forum MacReplies: 1Last Post: 14th Feb 2009, 18:30 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32 -
getting "fuzziness" in the simpsons, family guy...
By Sunshine1223 in forum Newbie / General discussionsReplies: 7Last Post: 22nd May 2007, 17:20
