TrendSetters
Is there a way to create a Play-All option in DVD Lab Pro so that by clicking on the PlayAll button, it will play several vids one after the other, then return to the main menu. It should be an option, not just stringing the videos together like a daisy chain. (This option is always available in TMPGenc DVD Author, so it can't be that hard).
Willing to Learn...but need Simple Easy instructions![]()
Go to the Connection tab, and connect all the movie together, one after another as it suppose to play.
And if you download the lastest DVDLAB PRO, the HELP feature is working now, read that section. -
Thanks for your reply, but as stated in my first post, I don't want to daisy chain the movies together. Yes I know this works, but I want the option to be able to (1) Select a particular movie to play, say the second movie of maybe three on the disc, or (2) If the movies are small and I want to park myself on the couch for awhile, I select PlayAll, and it does play them all.
Surely, if TMPGenc DVD Author can do this, and easily, then DVD Lab Pro should also be able to do it. Yes I could simply use TMPGenc DVD Author, but I prefer the safistication and bells & whistles of DVD Lab Pro. Why does it omit this very basic option -
Just Connection Movie 1->2, 2->3, 3->1. This way the movie will play in circle forever.
Then in the Menu Selection, make 3 LINKS, each link correspond to each movie.
This way you can select it to play from any movie when you first put your dvd in, and it will play nonstop a loop -
Look up the help file for Playlists - you can create a list of movie assets in any order to play back. Point the Play All button at the list, and the movies will play. Point a button at a movie, and only that movie will play (assuming you haven't linked it to anything else)
Read my blog here.
And this why i use DVD Maestro for my Authoring, at least with it i can have a play all button, and can play each episode individualy as well.
I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
Thanks Guys....The Play List magic did the trick.
Next job is to print the manual and set up for a good read -
I wouldn't call the playlist a "trick" because playlist was added especially for this reason to have play all or play "some" features. You can do anything in DVD-lab PRO playlists, even use chapter play list.
DVD Lab Pro help! Play animation after pressing button for playing video.
By visualhippocracy in forum Authoring (DVD)Replies: 3Last Post: 26th Mar 2011, 08:21 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 04:42 -
DVD Lab Pro Play all
By milway in forum Authoring (DVD)Replies: 5Last Post: 10th May 2008, 04:10 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 01:39 -
DVD Lab Pro - Play Chapter and return to menu
By SCDVD in forum Authoring (DVD)Replies: 4Last Post: 5th Dec 2007, 16:05
