When I enable progressive mode and play a DVD with film source, will it reverse the pulldown and playback 23.976 fps?
if nott here will be NASTY combing with the tv set to progressive.....
My TV suports progressive, is it stuck @ 29.970 fps, or will it do 23.976 fps?
TV's that say they have 3:2 pulldown correction, do they just stupidly blend the combed pulldowned frames and make it lok like crap?? Or wil it do inverse 2:3 pulldown and not require a progressive player???\
(Ive never had a p[rogressive tv before, and I need to know al these things to make sure my DVD playback is a s good as it can be.
yes it will reverse the pulldown and playback 23.976 fps
Wil the dvd player in progressive mode reverse the pulldown and play 23.976 fps, or wil the tv detect it and do it?
(Do I need a progressive dvd player) -
if your dvd layer can do it -- it will do it ..
if your dvd player can not do it - your tv will do it , assuming that your tv really can do it (some sort of fake it or just resize everything to 1080i)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Pulldown? when Encoding a 29.970fps progressive AVI to NTSC DVD
By FulciLives in forum DVD RippingReplies: 5Last Post: 27th Feb 2012, 19:00 -
Remove pulldown? (29.97 -> 23.976)
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2010, 19:12 -
Progressive vs. RGB output on upscaling DVD player & HD TV
By iansport in forum DVB / IPTVReplies: 5Last Post: 11th Jul 2008, 06:35 -
3:2 progressive scan pulldown support.
By wasimismail in forum Authoring (DVD)Replies: 47Last Post: 11th Jun 2008, 21:51 -
TMPGEnc: 720P -> Progressive or 3:2 Pulldown?
By akrako1 in forum Video ConversionReplies: 6Last Post: 13th May 2008, 12:51
