After downloading everything mentioned, and pointing to the uncompressed folder i got from the link (no real-libs file in sight) I get this message:
The Installation was not successful:
##sh: -c: line 1: unexpected EOF while looking for matching `''
sh: -c: line 2: syntax error: unexpected end of file
PS The mpeg2enc file has a .txt extension. Is that ok?
PPS All these files (mpeg2enc, mplayer, etc..) are located in Applications/ffmpegX as oppossed to Library/Application Support/ffmpegX. Should that be changed?
Thanks![/b]
Footbag Fanatic!
Check out: http://www.freedomfootbags.com/multimedia/lovely/A_Lovely_CSS5.avi
Missoula, Montana
VobSub 2.23 installation error when installing autogk
By carlos28355 in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2009, 22:11 -
error installing K-lite codec pack
By Shotobits in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2008, 03:38 -
Error After Installing Adobe Preimere Elements 4.0
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 10:15 -
Installing the open source encoding components
By three-cushion in forum MacReplies: 3Last Post: 25th Nov 2007, 22:07 -
Error while installing binaries!?? help!
By mavenny in forum ffmpegX general discussionReplies: 7Last Post: 8th Oct 2007, 23:29
