  1. I am looking to buy a new capture card and was just wondering wat composite means. Is it the yellow video wire that comes with the red and white audio ones? please help
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Yes, it is poorer quality compared to the S-video connection.
  3. its better than rf though isnt it? and i got a scart adapter too
    If you dont have an vcr/planning to buy one that have s-video output its composite you have to go with.
    Bcus i could only output in black & white on my old vcr tru scart adapter then i bought an svhs vcr with s-video output on the back then i got colourinto my tvcard.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Composite should be better than RF, by which I'm assuming you mean a signal modulated to a TV channel. I had to read about scart as I'm in Canada and scart is European. From what I can gather, a scart connection can be composite, component or S-video. Check out this document and the second page under RGB. http://www1.jaycar.com.au/images_uploaded/videosig.pdf
    So component (RGB) is best, then s-video, then composite. Then last would be a modulated TV signal.
  6. Like this for quality, nbr one is best:
    component
    s-video
    composite
    rf
