I've burned the cab files in the windows folder to create a win98 install disc and created a startup disk. Then i booted up from the cdrom drive and typed D:\setup (which is my cd drive), except it won't recognize it as a command to install win98 (bad command or filename). Am i doing this right?
what I would do
Burn all the files to a CD
Boot from a floppy
change to the CD
do a dir to make sure I can see the files
then type setup.exe -
Ya tried that too. I think it might be just a problem when i burnt the cd or something. Either way ill keep tryin stuff.
I think its because i burnt just the cab file instead of burning the options file which has setup.exe in it.
Another thing, would i have to burn those files in nero as data boot disc or just data? -
If you are booting to DOS from a floppy you must load the CDROM device drivers and MSCDEX.EXE in your autoexec.bat to allow DOS to recognize the drive.
BINGO!!!!I think its because i burnt just the cab file instead of burning the options file which has setup.exe in it.
Yep, makes it real hard to run setup from the CD, if it's not thereOriginally Posted by smearbrick1
Win95, Win98 and WinXP
By Jomapil in forum ComputerReplies: 9Last Post: 4th May 2009, 13:41 -
Win98 Generic drivers?
By bevills1 in forum ComputerReplies: 4Last Post: 30th May 2008, 14:44 -
Ipod and Win98?
By capman21 in forum ComputerReplies: 2Last Post: 27th Sep 2007, 12:04 -
I have to ask again, trying to installing Win98.
By capman21 in forum ComputerReplies: 45Last Post: 23rd Jun 2007, 12:38 -
Win98 update problem
By bevills1 in forum ComputerReplies: 22Last Post: 7th Jun 2007, 14:36
