I have a DivX avi file that is 576x240 @25fps
I tried encoding the avi to m2v using CCE SP 2.67 but when I put that m2v in DVDWS2 it wanted to re-encode - is this only because the frame size is incorrect? If so, what program can I use to change the frame size to the correct size so that DVDWS2 won't want to re-encode?
I recently did a different avi file that was 608x256 and it didn't have a problem with it at all...
there's so many options, is that all i need to do? just set the destination to DVD?
Can't change subtitle size on avi file
By jlulu1979 in forum MacReplies: 0Last Post: 11th Aug 2011, 18:41 -
Question Regarding Size Change from VOB to AVI
By vipin in forum Video ConversionReplies: 1Last Post: 9th May 2010, 22:46 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 15:45 -
Scriptable tool to change AVI frame rate metadata?
By FurrTheBear in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 01:43 -
Do I need to change AVI frame sizes before convertx to DVD
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 18th Nov 2008, 19:58
