I am torn between 3 systems. All are laptops
One has a 533MHZ Front SIde bus running a 1.7ghz Pentium M processor.
One has a 533mhz front side bus running a 3.30ghz Pentium 4 HT processor
One has a 800mhz front side bus running a 3.40ghz pentium 4 ht processor.
I am designing this laptop for high powered DVIX Conversions, DVD Ripping, downloading, traveling and graphics work.
Any ideas
BTW, Price is not really an issue.
Results 1 to 20 of 20
Price not withstanding is there any reason NOT to go for the best system?
Nothing can stop me now, 'cause I don't care anymore. -
Yeah the 800fsb with the 3.4ghz would clearly be the better system.
If price is not an issue, why not go with the fastest system? For me, those choices would be a no brainer. I'd go and get a nice AMD system! :P
Seriously, that P4 800FSB will rock.
Cobra -
Well I do use my laptop on the go, will the P4 give me enough battery life to make it useable?
None of those CPU's will operate at that speed if you leave the "config" set to portable/laptop. It "underclocks" itself to conserve power. Why run at 3.4Ghz to type an email when 2.0 will do just fine?
you should buy one of thoose motormaster Power boxes that are on sale for $149 that's what I'd do, you'd get a work out to lugging around.
so ur saying i can "dumb down" the 3.4ghz cpu when i dont need 3.4ghz? I didn't really know how to do that
i was supposed to be able to dumb my 866 down to 666 but it never worked. -
That's because it's the mark of the beast. :POriginally Posted by Greg12
Almost all new laptops will underclock when on battery. Most will let you set the level of power you want with some control panel applet. If battery life is a major concern go with either a P4M or a Centrino.Nothing can stop me now, 'cause I don't care anymore. -
I didn't think they were putting the P4HT's CPU's in laptops because they were a battery drainer and the ran smoking hot and the fans in a laptop were not sufficient.
It won't be as fast as the P4 with HT. It's a tradeoff. You're going to sacrifice some performance for battery life.
Don't expect to encode anything on battery life either.
Like ViRaL1 said its a trade off, the P4 is faster but the M uses less power.
You could always buy a powerbook?
I decided to get
3.4ghz 800MHZ front Side bus with hyper threading
512RAM
100gig HDD
128 ATI Graphics card (i wanted intel extreme ccause it's soo cheap)
802.11g wireless -
Where did you get it all from?
Originally Posted by lordsmurf -
[img]http://rds.yahoo.com/S=96062883/K=dell+guy/v=2/SID=w/l=IVI/SIG=11i0jakbc/*-http%3A//www.tvacres.com/images/dell_dude3a.jpg[/img]
"Dude, you're getting a Dell?!?!?!"
:P
Thank God those commercials have disappeared. That "dude" guy was annoying!Ethernet (n): something used to catch the etherbunny
Moving between Avid systems
By Jorx in forum EditingReplies: 0Last Post: 4th Nov 2010, 06:03 -
Running two Operating Systems with one PC?
By neworldman in forum ComputerReplies: 7Last Post: 21st Jul 2010, 18:45 -
64 bit op systems
By dblake2 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2008, 16:44 -
Compression systems used for Broadcast TV
By dtvdrb in forum DVB / IPTVReplies: 0Last Post: 5th Jul 2008, 10:42 -
water cooling systems
By romanstopme in forum ComputerReplies: 18Last Post: 29th May 2008, 10:12
