Hey guys...heres the deal:
I have tried encoding a DV file to DVD using TEMPGenc using ES and System setting and getting the same results. The ripped DV avi file contains audio, but cane not rip the audio using VirtualDub...i get a silent 4 second clip, same with TEMPGenc Wav rip tool. Maybe this is a simple fix or maybe i should go into more detail. Please advise fellas, thanxs.
I'm not really familiar with DV but maybe your DV file is the wrong type. In that case you need this Ulead DV Type 1 to DV Type 2 Converter. There's a similar tool from Canopus as well.
VirtualDub and TMPGEnc will only support DV type 2 format.
If your files are DV type 1, try the converter; but keep in mind that if the video file is too big, the converter will not work properly.
Try re-capturing your movie in a DV type 2 file. Use WinDV for the capture. -
I did use WinDV, and also tried windows movie maker aswell. The file as far as i know is Type 2. Any other suggestions?
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
FAVC dropping 6 channel audio
By midders in forum DVD RippingReplies: 3Last Post: 10th Mar 2009, 19:36 -
MKV to MPEG2 - Not dropping frames, but not smooth - think it's audio
By Shade00 in forum Video ConversionReplies: 11Last Post: 18th Feb 2008, 13:20 -
DVDx dropping audio at end of vob
By shira in forum DVD RippingReplies: 0Last Post: 21st Jan 2008, 22:42 -
Dropping audio on capture
By joe1541 in forum Capturing and VCRReplies: 5Last Post: 28th Oct 2007, 19:07
