ADVANTAGES DISADVANTAGES OF DVD+R vs. DVD-R???
Should I care?
DVD-R is cheaper and more compatible (with the right brands). I have personally found that Ritek/RiData DVD-R have the best compatibility at a reasonable price.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
There werent any personal advantages to +R until the recordable dual layer format was released. There is no dual layer -R yet.
is this somehow a mac-specific question?
in mac-land, DVD-R is most compatible for the burners that shipped with the G4s.
dk -
Also, Apple initially limited iDVD and DVDSP to burning to DVD-R only. I think newer versions of DVDSP may allow DVD+R burning - if the burner supports it (and if Apple hasn't disabled that funtionality with the firmware they supply on their "Superdrives") - but the Apple iDVD Help site for iDVD 4.0.1 states: "When you are finished with your iDVD project, you can burn it to a blank DVD-R disc."Originally Posted by decay
Link: http://docs.info.apple.com/article.html?artnum=150511
So, the only Mac-specific issue with DVD-R vs DVD+R is Apple's initial "DVD-R only" stance, which is slowly changing to allow DVD+R.
Mike"Dare to be Stupid!" - Wierd Al Yankovic -
basically as long as you are running 10.3.x and have a dual format support drive use whatever you like.
personally i like the Ritek G05 -R myself, but i can also burn +R and Dual Layer +R if I want
advantages of transcoding mpeg2
By codemaster in forum EditingReplies: 4Last Post: 26th Apr 2012, 16:11 -
What advantages are there in using .MP4 over .MKV if any
By Onceler2 in forum Video ConversionReplies: 2Last Post: 26th Jul 2011, 15:53 -
Advantages of ISO?
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 27th Sep 2010, 17:42 -
Analog TV-Monitor Advantages?
By therock003 in forum Newbie / General discussionsReplies: 37Last Post: 27th Jan 2009, 16:57 -
What are the advantages of a dvd recorder over tivo?
By zanos in forum DVD & Blu-ray RecordersReplies: 28Last Post: 29th Nov 2008, 12:44
