hi, i managed to convert my divx file into dvd files with dvd santabut then i set everything ready to burn with nero burning rom after 1% i got an error message
saying "Power calibration error"
can anyone help me help??
heres the log file that i saved, if that helps:
Tony
yard
1A23-0007-5030-1259-8396-6342
1A4C-0800-0000-1278-3505-3952
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
Nero version: 6.3.0.2 (Nero Express)
Recorder: <PIONEER DVD-RW DVR-107D>Version: 1.10 - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-107D>Version: 1.10 - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD204AA-00BAA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-107D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY CD-ROM CDU5211 atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-107D D: CDRom0
SONY CD-ROM CDU5211 E: CDRom1
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 213MB (218416kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.10.2004
UDF/ISO compilation
20:37:44 #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
20:37:45 #2 Text 0 File DVDVideoCompilation.cpp, Line 540
Content of VIDEO_TS.IFO has been modified
20:37:45 #3 Text 0 File DVDVideoCompilation.cpp, Line 540
Content of VIDEO_TS.BUP has been modified
20:37:45 #4 Phase 113 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed
20:37:45 #5 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
20:37:45 #6 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
20:37:45 #7 Text 0 File Reader.cpp, Line 118
Reader running
20:37:45 #8 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-107D running
20:37:45 #9 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
20:37:45 #10 ISO9660GEN -11 File geniso.cpp, Line 3882
20:37:45 #11 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
20:38:08 #12 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2225215 (494:29.40, 4346MB)
20:38:08 #13 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
20:38:08 #14 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: PIONEER DVD-RW DVR-107D, Media type: DVD-R
Disc Manufacturer: INFOSM - ART01
Disc Application Code: 64, Disc Physical Code: 193
20:38:08 #15 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW.)
20:38:08 #16 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2225216 (2225216) = #2225216/494:29.41
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2225216 blocks [PIONEER DVD-RW DVR-107D]
20:38:08 #17 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-107D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4557242368, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2225216 | lead-out | 1 | 0x00 | 0x41
20:38:08 #18 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
20:38:08 #19 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
20:38:08 #20 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
20:38:08 #21 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5,520 KB/s)
20:38:08 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
20:38:08 #23 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 13:48,289 (828289ms) -> OK
20:38:08 #24 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
20:38:08 #25 Text 0 File Mmc.cpp, Line 19451
Set BUFE: supported -> ON
20:38:08 #26 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
20:38:08 #27 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
20:38:25 #28 Text 0 File Cdrdrv.cpp, Line 1277
20:38:25.802 - PIONEER DVD-RW DVR-107D\H1 T0 : Queue again later
20:38:44 #29 SCSI -1106 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x04700000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x73 0x03
20:38:44 #30 CDR -1106 File Writer.cpp, Line 301
20:38:44 #31 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
20:38:45 #32 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
20:38:45 #33 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 767
20:38:45 #34 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
20:38:45 #35 Text 0 File dlgbrnst.cpp, Line 1658
20:38:45 #36 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'WNASPINT.DLL': Ver=V1.18, size=57344 bytes, created 02/11/2002 09:53:04
File 'Drivers\PXHELP20.SYS': Ver=2.03.01a, size=20368 bytes, created 17/10/2004 15:06:53 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 04/08/2004 06:59:42 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
please wait a few days before you bump a topic. this is no realtime chat.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 10:02 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 01:01 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
