I downloaded some Video via firewire & ULVS to my pc which works fine and plays fine on the PC. The problem I have is when I export it back to the camera and try to dump it from there to VHS tape. The picture quality is poor and the audio is choppy. If I use digital stills in ULVS and create an AVI, export it to my DV Camera, and record it to VHS both the pictures and the audio I added play fine. Same tapes in both camera and VCR. I normally record to DVD but I had a request for a VHS version of the video. Any idea why the video avi is having problems when I put it back on the DV camera? The only encoding difference is the stills use DV Video Encoder Type 1 and the video I used DV Encoder Type 2
I would say your easiest solution would be to dub it to VHS off the DVD you created. Just hook up the Video and audio RC jacks and dub away.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Interestingly enough there is a bug in ULVS 7 that creates this problem. They have a patch to resolve it, I applied the patch and now the software no longer recognizes my camera. Upgraded to version 8 and now it sees my camera, the video quality problem is fixed but the audio tends to crack or pop. Works fine when recorded to dvd
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 15:57 -
Camera live feed to TV through VCR.
By Tinker01 in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2009, 19:18 -
Capture from VCR or Camera?
By thomasj in forum Capturing and VCRReplies: 3Last Post: 26th Nov 2008, 15:13 -
Using a DV camera to import tapes from another DV camera to desktop
By bge20 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2008, 19:03
