I am using WinAvi to convert AVI files from Adobe Premier to DVD-ready files. Should I be converting them to MPEG2 or .IFO/.VOB/.BUP files?
The only authoring program I have is ROXIO EASY CD/DVD CREATOR 6. Maybe somebody could also offer suggestions on getting home video edited in Adobe Premier to DVD.
just click the "DVD" button,add the file,then wait.
itll make dvd compliant vobs,ifos,etc. -
For anyone who is familiar with WINAVI:
If I have three separate AVI files edited by Adobe Premier, and I want all of them on one DVD...
...Can I convert each one individually from AVI to DVD (.BUP, .IFO, .VOB) and then burn them using the WINAVI? If so, will I be able to switch between each of these three videos on my standalone DVD player as I would regular chapters in a DVD? I realize there won't be a menu, but I just want to know if this would work and if I could skip through one video to the next.
I have discovered that Roxio Creator Classic only allows you to create DVD-ROM. It does not specify DVD-VIDEO as a selection, and so I have had several failed attempts.
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 07:50 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
WinAVI 8.0 - DVD to AVI - Target Size 700MB?
By ivisitpublix in forum DVD RippingReplies: 2Last Post: 24th Aug 2007, 14:01 -
avi to dvd converting settings for winavi convertor
By soft in forum DVD RippingReplies: 6Last Post: 24th Jul 2007, 00:45
