Hi, im in desperate need of help, im currently putting 3 avi files onto dvds, 1st by saving wav file in virtualdub, then using tmpgenc to make mpeg using dvd settings set to cbr 2000 which works and allows me to get 3 onto a disc, the mpegs come out and work perfect. I then use dvdlab and import the mpegs using dont demultiplex because when i do i sometimes get errors, this works but about 3 out of 10 i get sync problems with, if i check say vob4 which has the beginning of the film its fine but then vob 5 will be out of sync by up to 5 seconds, is there anyway to fix this, i think its something to day with the way the vobs are split. Is it possible to get dvdlab to split after each film or does it have do be after 1 meg or so, please help
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 06:32 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 16:00 -
wmcapture sync problems?
By the_doc735 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Apr 2009, 16:32 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 21:38 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 17:28
