Hello,
I have a couple .MOV and .AVI clips off a digital camera that I wish to extract the audio from.
I've made attempts at Mov->Wav using TMPGEnc w/ the QT plugin, but ended up with soundless wav files. GSpot reported the .mov files to be "Non-AVI File - Type Unknown" and is unable to render them.
With Avi->Wav in TMPGEnc, I got wavs that were either distorted? or lost audio quality.
Forgetting my earlier attempts, given the files off the camera are already of low quality, my main concern is to successfully extract the audio without furthur degeneration - and perhaps improve the sound quality?. How can I accomplish this? Are wav files the way to go, and are there any ways to enhance the quality?
The .Mov file audio specs are as follows:
Sample Rate: 7867 Hz
Channels: Mono
Sample Size: 8 bits
Compression: None
Avi:
11024 Hz
Bit Rate: 88kbps, Mono
Sample Size: 8bit
Format: PCM
Use Quicktime Pro.
Open your .MOV file (you could also open your avi files here, if they are MPEG-4 format).
-> EDIT -> EXTRACT TRACKS ->
choose Sound Track (a new window will open that contains just the audio) -> (in the new window) FILE -> EXPORT
Et viola.You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
AVI audio is most easily extracted using Goldwave. Just load the AVI, Save wav. Or use VirtualDub
/Mats -
Thanks, I'll try using Goldwave for the AVI.
Is there another way of converting the .MOV without Quicktime Pro?
Also, is .WAV the format I should use to prevent quality loss? -
Seems like they both contain pcm/uncompressed audio files (both mov and AVI), which is wav, so no loss here... But they are low spec wavs, so you shouldn't expect miracles regarding the quality. Maybe some filter might encahce things a little, but 7867/11024 Hz 8 bit samples aint much to work with...
/Mats -
Xilisoft Video Converter, a new product, is easy to realize the function. You can rip .mov and .avi files to wav, mp3, aac, wma, etc.
Rad Video Tools will also let you extract audio from .Mov files, as well as convert to AVI. EO video also works.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
extracting closed caption from quicktime(.mov) file
By kafkatedsoul in forum SubtitleReplies: 3Last Post: 12th Jul 2010, 17:06 -
Problem at Adobe Premier 6.0 : Extracting .MOV movie
By chineloninja in forum EditingReplies: 1Last Post: 8th Jul 2008, 18:03 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 15:04 -
Extracting audio from AVI's
By KoolDrew in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 20:24 -
Extracting audio from avi - only does first 13mins
By DBIV in forum MacReplies: 5Last Post: 21st Jul 2007, 20:27
