I have a wrestling dvd and I would like to split the dvd to two dvd-r's and keep the menus intact. Any guides on how to do this? I know wrestling looks bad when shrunk to 4.3 gig. thanks
do a search for 'split'
there's a few threads about this and this was the most recent
https://www.videohelp.com/forum/viewtopic.php?t=240823
there's also the guides on the left -
Wrestling looks bad, period.
But in general what I tend to do is just blank out a title or two.
For example, I have a new disc that someone put together of "The Bourne Identity", the TV miniseries from Europe starring Richard Chamberlain and Jacquelyn Smith.
The first "part" (actually two 40+ minute episodes) is held in VTS_01_01.VOB through VTS_01_04.VOB, and the second "part" in VTS_01_05.VOB through VTS_01_08.VOB, so I just don't copy over those VOBS I don't need, and then use one of the menu tools commonly available here to remove the button for the missing part.
However, if everything doesn't break down that easily, there certainly are those guides. Just trying to save you some work, as stuff that was intended to air on TV (episode discs, for example) are often broken down for you already, and hence easy to split with little work. -
Originally Posted by nick101181
http://www.doom9.org/index.html?/mpg/ifoedit-2dvdrs.htm
The only thing I do differently is to put the extras on both DVDs if the actual movie is over 4.3gb
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
DVD9 split to two DVD5's while retaining menus and video quality
By ashes2flames in forum DVD RippingReplies: 6Last Post: 28th Feb 2011, 08:10 -
Guide "Replace DVD Menus With VobBlanker"
By skaleton in forum Newbie / General discussionsReplies: 2Last Post: 30th Aug 2008, 12:12 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 20:22
