Results 1 to 9 of 9
  1. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Can anyone explain these reading. On the first site I get a very fast reading. On the second they say it's slow. Is this a con? BTW I have optus cablle
    [/img]speed3
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    It's all meaningless because the number of nodes is different between you and the server with each benchmark site. And it'll be different when you're actually on the web, so what's the point?
    USA
    I'm always suspicious of test results when they are trying to sell me something. I use this site, though from your location it might not tell you much. http://www.broadbandreports.com/stest
    You should be able to find a similar site closer. You should check several times during the day, and with different test servers to get an average. My cable down speed varies from a low of 300 to a high of 3000 at different times during the day.
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    because cable is shared, your not the only one using it which means when more people are on the slower your connection. i judge mine by what speeds im actualy downloading at when im downloading a file from a fast server.
  5. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    Second one is a scam... Today I was testing my work T3 line and used one of these test sites and my reading was thru the roof.. Guess what, they said I needed to buy some optimization software to make it that much faster
  6. Originally Posted by Dr. DOS
    Well did you??? How much was it if you did????
    makntraks
    In the theater of the mind...
    It's always good to know where the exits are...
  7. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    Anything less than an OC-192 is crap. Splurge a little.
    Nothing can stop me now, 'cause I don't care anymore.
  8. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    makntraks
    Nope, but I should have
  9. Master of Time & Space Capmaster's Avatar
    Feb 2004
    "We'll sell you this nice spiffy internet frame relay backbone node for the sale price of juuuuuust $18,250 dollars a month, on the easy pay plan"
