like I have a .vob file and when I put it in toaster it came up as like 5gb and my blank dvd thing is only 4. something. So yeah how do I like compress or shrink the .vob file?
You can use ffmpegx's dvd 9>5 in it's tools section. There was also the freeware Minx Transcoder. Which doesn't detect pulldown, but will do the job on most standard vobs. Otherwise you can author a VIDEO_TS with apps like DVD Imager or ffmpegx or Sizzle and then shrink that with DVD2OneX or DVDRemaster.
Well, like, you should like use like, an application that will, like, shrink your dvd, like, down. I suggest you use, like, DVD2OneX, because, like, thats what has been suggested in this forum, like a million billion times.
Also, like, you can't just, like put a .vob file in, like, Toast (what is toaster? Do you mean Toast?) and have it, like, burn properly. You, like, did use a VIDEO_TS folder, like, right?
I will admit that you only used the word "Like" twice in your post. I don't understand why people use that word so often in normal speech, and the reasons for using it on a forum confuse the hell out of me.
So, in conclusion, I assume you're trying to burn a VIDEO_TS folder, and not a .vob, because you shouldn't ever have a vob that is 5GB, but you easily might have a VIDEO_TS that is. Use DVD2OneX to compress it to something like 4444MB and then try to reburn. If you actually have a 5 Gig vob file, you have to do horrible things to get it to play. Or not.If it isn't broken, take it apart and find out why.
blog: deadsierra -
i would also like to know
is it a 5 gig single .vob file?
but if its a video_ts folder the previous posts will set ya straight
shrink a vob file
By natty in forum Newbie / General discussionsReplies: 13Last Post: 5th Dec 2011, 14:06 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 23:19 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
How to Shrink 7.7 GB VOB files to 4.7GB DVD on MAC?
By mc80 in forum MacReplies: 5Last Post: 30th Mar 2008, 10:41 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 18:39
