Whenever I capture a program that is broadcast in letterbox (like "ER"), I notice that there is often noise in the black-barred area.
Suppose that I plan to take a typical AVI video with this situation and encode it to VCD using TMPGEnc without changing the aspect ratio.
Is it better to:
1) clip the letterbox out and mask it back in
or
2) just encode the file as is
My thought is that option 1 would allow better quality in the actual content area since there won't be any wasted encoding of the noisy letterbox area. Is that true?
Thanks,
BG
Crop out the black area, and use the anamorphic template.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Would that be the same as clipping and setting the Video Arrange Method to Full Screen (Keep Aspect Ratio)?
Thanks Again,
BG
Understanding TMPGEnc source material settings
By brassplyer in forum Video ConversionReplies: 1Last Post: 5th Mar 2011, 06:41 -
Why does converted HD to SD file show video as letterbox using Tmpgenc?
By Endoking01 in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2010, 21:37 -
TMPGEnc, Vobsub and mpg files as source
By kubak in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2009, 16:52 -
De-interlacing video captured from a standard AV source
By Garblefunk in forum Newbie / General discussionsReplies: 33Last Post: 4th Jan 2009, 06:49 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
