Is there a way to put an 84min video on a 80min CD?
I use Nero
Not if you are making a standard VCD. But what is your source? What do you want convert to?
i have an mpeg file that i want to make into a vcd but its a few mins over the 80min CD-R limit that i got
Originally Posted by LAX
You can use Nero to create a VCD if your mpg is MPEG1 or a SVCD if your mpg is mpeg2. Select New Compilation, click the VCD template, then drag and drop your mpg file into the MPEGAV folder. Nero will then encode the mpg and author VCD files to fit your media. -
Or make a 1/4d1 dvd eg vcd res but mpeg2 .. still use VBR on your encode... can look better than mpeg1.. or just use a lower than normal bitrate on your mpeg1 vcd, eg 1020kb/sec rather than 1100 and it should fit.
(its just historical artefact that mpeg1 bitrate "fits" a Cdr time wise.. old VCD players could only spin the disc at x1, thus determining the max bitrate)Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14
