Version 1.21
This with this GUI you will be able to load two motion menus. Freeze the last frame of the first and the first frame og the last. And add a transition.
(The rendered motion menu transition can then be added to GUI for dvd author or Dvdauthor GUI)
Download from here:
t4dvdm.zip
Or try here:
t4dvdmenu
Files needed:
Avisynth
MpegDecoder.dll in Avisynth/plugins
and
an avisynth encoder ex:
FreeEnc
(or try NuEnc or QuEnc)
and
a mpeg player ex:
Media Player Classic
Have fun...
tin2tin
[edit: 30.10.2004 - Fixed an interface loading bug]
Results 1 to 9 of 9
Fixed some bugs and changed the look of the GUI
[due to a limitation of mpegdecoder.dll it is not possible atm. to use clips of one frame length. Use longer clips than one frame(motion menus)]
Tin2tin -
A transition render version direct for GUI for DVDauthor.
Just unzip the files in the GFD folder where QuEnc also is, and you're up and running:
Download here:
GFDT
Btw. no automatic opening of a player afterwards.
Have fun,
Tin2tin -
I'm sorry to bump, but I'm just curious - does anyone have any troubles with this? - is it working for you? Any thoughts or ideas?
Btw. A DVDauthor GUI way to add a transition.
Tin2tin -
Actually, the latest DVDAuthorGUI incorparates that concept directly into the program. (JumpTable, under 'tools' must be turned on). I haven't had a chance to test your program, but I plan to when i get some free time this week. It looks very interesting.
Hi,
I've used the same method to render slideshows with:
DVDslideshowGUI
Have fun,
Tin2tin -
Does this reencode the whole thing, or just the last & first frames? Hmm, looks very handy.
Adding transitions to videos with free software
By Cyber Akuma in forum EditingReplies: 61Last Post: 8th Dec 2010, 12:36 -
DVD slideshow GUI transitions
By dread in forum Authoring (DVD)Replies: 1Last Post: 14th Nov 2008, 14:05 -
GFD - transitions between menus
By dani96 in forum Authoring (DVD)Replies: 0Last Post: 24th Jul 2008, 07:23 -
GUI for dvdauthor - continuous music over menus?
By GeorgeLucas in forum Authoring (DVD)Replies: 2Last Post: 27th May 2008, 19:20 -
Looping audio on GUI for DVDauthor menus weird problem
By chewie8008 in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 10:16
