I've got a bunch of divx movies. Is there an app that will let me take the audio from the divx movie and convert it to 5.1 dolby digital?
I guess it will involve splitting the audio into 6 streams or something similar.
thanks in advance for any responses.
here try this link. i think this is what you want.
http://www.martinchris23.pwp.blueyonder.co.uk/divx_to_dvd.htm
Good luck -
there are are many methodes around - if you already have an AC3 you only have to mux it to your video stream
else
take a look at this list of guides http://forum.doom9.org/showthread.php?s=&threadid=83752
CYA Daphy -
You can try, but unless the audio is already Ac3 5.1 its probably not worth the effort, the final result really isn't much better than stereo, may even be worse. If the source is stereo and you want to go to DVD, use Ac3 2.0. Thats my suggestion anyway.
How to create AVI with 5.1 sound for Xbox 360
By thoughton in forum MacReplies: 25Last Post: 22nd Dec 2011, 04:11 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Using DVDLabPro to create a "sound effect" button?
By takearushfan in forum Authoring (DVD)Replies: 7Last Post: 1st Jun 2010, 19:53 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Vegas: how to create a h264 video with surround sound?
By grendizer in forum EditingReplies: 4Last Post: 7th May 2008, 14:29
