I have several mpeg clips with multiplexed ac3 5.1 audio.
All I want to do is trim the beginning and ends with a fade to black but the software I have will either NOT re-encode DD 5.1 audio (like Ulead Video Studio & Media Studio Pro) or only do simple trimming (like TMPG enc).
After this process I want to join the clips together acomplete with the 5.1 audio.
I'm currently having a look at Womble mpeg2vcr (latest version) as it has an 'insert effect' option but can't even output a saved file for some reason.
Any other options?
PS
I won't touch any Pinnacle software, way too unstable!
Cheers
If you can rip the audio out of the video as is you can import it into Ulead DVD Workshop as a replacement audio file and select "do not convert compliant files" when you get to the burn options. I know this will work with Workshop.
You may also be able to do the same thing with Video Studio if it supports AC3 but I don't know for sure. You would have to create your new video with the fades then replace the audio after encoding with the ripped audio. Worth a shot -
Thanks, yes I can isolate the audio track ok and manipulate the video in several programs. I just need a sound editor that supports ac3 5.1 and allows fading, but this will then need to be re-encoded which is where the the problem lies (expensive Dolby licensing).
I don't know of a program that will let you edit .ac3 audio in that form. I've looked but haven't found one.
What I have done is to convert .ac3 > .wav and edit in Sony Vegas. Then render as .ac3. There should be trial versions of Vegas out there for you to mess with.
Simple DVD editing and encoding software? (Scene release)
By djkilla in forum Authoring (DVD)Replies: 4Last Post: 18th Nov 2011, 08:48 -
Advice for simple, free video-editing software for a newbie
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 4th Sep 2011, 22:25 -
Best audio editing software?
By Hank Kinsley in forum AudioReplies: 20Last Post: 9th Mar 2011, 11:15 -
Simple video editing, involving MKV with 2 audio tracks and subs
By James1982 in forum Newbie / General discussionsReplies: 1Last Post: 29th Nov 2010, 00:30 -
Question about simple software to convert mp3 to burned 74min audio CD
By jimdagys in forum AudioReplies: 5Last Post: 10th Jun 2009, 07:42
