  1. I have the latest Nero (6.3...), and I can't burn the two-cd mpg2 movie that I have. The size of each clip is 772 mb, so it should be no problem burning it as a SVCD.
    I have encoded the streams from DivX avi with TMPENC, with 480x576 and 1900 bitrate, and I have had no problems burning movies the same way with even higher bitrate, up to 2400 sometimes.
    I have got this problem a couple of times before, but then I quickly fixed it by re-clipping the movie, like taking away 1 second from the beginning and 1 second at the end, but it does not work for this one.
    I have tried many clipping programs, including mpg2cut2, AVI/MPEG Splitter, Easy Video splitter etc.
    What can I do? I don't want to click "re-encode the file" in Nero since I'm afraid the quality will literally suck, and it doesn't even say how much time is remaining in goddamned Nero Burning Rom.
    I have also tried doing VCDEasy .bin file of it to burn it in Nero, but the file size is too high for SVCD (772 mb, original size).
    Please help me
  2. Did you try the MPEG tools in TMPGEnc?
  3. I used the MPEG Tools now, and did a simple multiplex thing. It fixed the problem! Thanks.
    (mods - lock the thread if you like)
